Root Help. Need secure PC36IMG_RA_2.3.zip
Hello Android Forums!!!!
I just unlocked my EVO following this tutorial...
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
Everything went good until I got to "Step 2: How to get Recovery".
A link is given to download PC36IMG_RA_2.3.zip but the address is blocked by my work. Is there another secure location I can download the file from?
I am kinda stuck, lol.
Thanks!!!
Can you download from a dropbox? I have a copy on my DB
Edit: here ya go! and Welcome to AF!!!
http://dl.dropbox.com/u/58324641/PC36IMG.zip
Or did you need the one for software v 5.xxx? If so, here is that one from my DB---
http://dl.dropbox.com/u/58324641/PC36IMG_AmonRA-v2.3-hausmod_revA.zip
Sorry, just noticed your post. I ended up finding one.
I have one more question though, that I bet you can answer.
When moving a new rom over to the SD card, do you make a new folder for the ROM then drop the unzipped contents in or just drop the contents on the SD card (three folders and the boot.img)?
Thanks again
Thanks again
Well, first of all, do not unzip the rom .zip...leave it zipped up.
And secondly, you can put it in a folder, or on the root (top level) of sd card.
I usually just drop it on the sd card.
Either way will work, you can find it in recovery.:)
Ah, poop. I unzipped it on my comp and was gonna drop it on the there. Okay, so I will take the zipped file I downloaded and just drop it on the SD.
Dang it. I did the same thing with the "super wipe", I unzipped it and added it.
Yeah, usually leave something like a rom zipped unless specified in the op of the rom...then yer good to go.
Happy flashing!
