Help Help!!! Router can only connect to one X10
leo77
2
0
Hi guys, Please help with this issue.
Me and my brother each bought a Sony X10 lately which both with 1.6 system. We found our TP Link Router (G) can only recongise one of them. Every time after rebooting the router, who ever connected to the WLAN first can have access to WLAN and the other one will have failure message instead. So at moment we have to keep rebooting the router to share the WLAN.
Can anyone let me know if this is because of the router itself or the phones?
Apprciated
Apprciated
A few things to try
ROUTER
Change the WIFI Channel
Change the Encyrption type of the router (wpa / wpa2 )
AS A TEST ONLY - Remove the security on the router and try and both connect when OPEN, to see if that helps BUT DONT LEAVE IT OPEN.
PHONE
Try updateing the phone software as 1.6 is old.
Good luck
Upvote 0
A few things to try
ROUTER
PHONE
Good luck
Sorted, Thanks wynney666
Borrowed my friend's Linksys and tried at home, works all good now. Looks like I need a new router.
Cheers guys
Upvote 0
BEST TECH IN 2023
Smartphones
