Root Help with network mode
NikeBoy42
I was on CM10 and I went back to Samurai Rom But i forgot to change the network mode back to LTE and now i have no 4G help please
You have to flash cm10 again and change it back to your correct settings and then when you flash back to samurai everything should be working.
Or retrieve you msl code with meid converter app from the play store its free,then from phone dial ##626* enter your msl code you get from app.then scroll down to were option NETWORK MODE is click on it you can change it from there without having to reflash anything.:thumbup:
Edit ....this only works with stock based Roms such as samurai...
