Hi, i am having an issue with the sound on my San Francisco 2. All is fine when i listen to music through the built in speaker or the headphones but when i try to plug it into an external sound source (a power amp/mixer) the sound is very distorted and i am getting no vocal, it is also very tinny. I use the same cable for my laptop and have no problems with that.
Any help or advice would be awesome
Thanks
Kevlar
FOLLOW UP:
I got it to work using 3.5mm Aux Cable To 2 RCA. Still no joy with 3.5 to 3.5....but it works
Hope this helps if someone has the same problem
Thanks
Kevlar
FOLLOW UP:
