Root Help: Won't boot properly
Mehta23
Android Expert
So I turned off my phone for the first time since installing CM10.1 RC1. Upon reboot, the boot animation just plays... it doesn't restart, so I don't know if it's still a "boot loop"?
I got frustrated, so I managed to finally get into the bootloader (it's harder without a properly working volume down button :P) and wiped everything and reinstalled CM. But is there a way to recover my data ? The only thing I backed up was the DATA section from recovery ...
Help?
if you backed up the data partition,just restore it :) however whatever was causing the no-boot issue may have been backed up alond with it,depending on exactly what it was,so you maY BE forced to go back and rewipe,reflash,and reset up from scratch if you have issue after the data restore.
Tried restoring the DATA backup, seemed to go well, but it froze on "Android is upgrading apps". A reboot sent it into the boot loop again :(
