Help ho to move a file to my sd card
I haven't been able to cut and paste either.Copy works good and then you have to remember to delete afterwards or you have duplicates.
Another think that is weird. If you select multiple files to move and after your done pasting them and you try to move another file the old ones you just pasted are still there.They don't clear out of memory or something like that. At least for me...
Yep its kind of a drag to have to do an extra step but that is the only I can figure how to do it.
I have found file manager HD to work a bit easier. Still have to do all the step but its visually appealing. I had astro for that same reason mentioned above but figured out that file HD can do the same just as easy if not easier.
I just get a file manager called file expert. Its free and is a great file manager try it out. It let me cut and paste. I haven't tried a lot of files but the two T tried worked...
Oh and no ad's
File Expert and ESFile Manager work well. I have found ES works better with the network. Astro crashes with the network and Bluetooth options.
I wanted to save multiple photos from my camera's sd card to the micro sd card in the acer & then copy those files to a usb thumb drive--would I be able to do this without too much trouble? Thanks so much.
YEP... Just follow the steps above. The places your moving files from are different but overall the same
