Home++ conflict?
I recently found (and fell in love with) S2 Calender widget (it shows the different dates in the monthly calender in the color of the calendar appointment slotted for that day. I just put in Home++, and now find that S2 won't work, as it won't show the different colors in the widget. Am I missing something, or is Home++ just not quite there yet with the widgets?
Actually, I tried both. After I installed H++ beta (maybe that's my problem), I deleted all my widgets and shortcuts, so I wasn't running them twice. When I set up the widget, it didn't show any colors. I then uninstalled it, and started fresh, but no luck there either. Are the colors showing up on yours? Also, is your home++ the beta?
Upvote 0
I just installed home++ yesterday. And s2. Calendar app
Upvote 0
I just noticed that all your weekdays are the same color. How can you tell what's coming up? On my native home screen, it's got all the colors of my varios calanders showing. I don't see that in yours either.
I guess you might be on to something .....to view upcoming events I have to tap on widget...I really haven't got involed that much this app since its kinda new to me...but imgoing to go check the settings
Upvote 0
OK, I got it to show the colors. I installed H++ again, only this time I left all my shortcuts and Widgets up. I setup S2 again, and it started out colorless, and then popped into the proper perspective, colors and all. I have since deleted the one I'm not using, and all is right with the world....or at least my Droid.
Upvote 0
rcballard
If I did this right, you should be able to see S2 in the upper left corner. Each color is a different appointment on that particular day. Green is one type, orange another, and so on. You may want to delete your current one from H++ and do it in the order I did, assuming you want what I do from the widget.
Upvote 0
rcballard
Upvote 0
BEST TECH IN 2023
Smartphones
