Help How do I send large videos or mp3s to another phone
You can use dropbox and send your friend a link to the file. What you would do is store the file or files you want to share in the public folder in your dropbox on your phone. One you do this you can long press on the folder to generate a link you can email or text to your friend. They, in turn can launch to that link and download the file(s) you posted!
I help this helps you!
If you want to try dropbox, which is free, by the way, please use this link from me as for every referral they increase the amount of storage space you get for free!
Link:
http://db.tt/S7QuzpW
Good Luck!
  • Like
Reactions: sailorruby
Upvote 0
BEST TECH IN 2023
Smartphones
