brezzo
I'm just curious as to how much battery life everyone is getting. I don't know what happened but mine suddenly got crazy good o_o
After 15h 16m 30s on battery, I still have 70%!@!@
This is the happiest moment of my android life
Just thought I'd share some battery saving tips, and if others want to share theirs that'd be awesome too.
I'm running Cyanogenmod 7 with the stock Cm7 kernel.
Also, I'm using Green Power Free from the market, which disables wifi and data, and enables it at chosen intervals to check for notifications/etc. I have it come on for 5 minutes every 30 minutes, which is one of the more frequent settings and it seems to work quite well.
Also, when not using data (mainly because the 3g coverage is crap in my area), I enable only 2g networks and disable data. This makes the phone not keep trying to get a 3g connection when it doesn't need it
My brightness is also at 60%.
Please post your tips/battery life too!
