Hard resets wipe the user /data partition... but it doesn't overwrite the custom Recovery (TWRP or ClockworkMod). What you'll want to do is read, read, read, ask lots of questions, completely charge your phone and replace the custom Recovery with the stock Recovery. Then unroot it. Make sure that SuperSU is uninstalled and reset it again. You should be completely back to stock. You may even want to Odin back to stock. Hope this helps.
