how to get "Droid" notifaction on eris ???
I think it would be pretty cool if there would a way to get the droid notification bar on the eris. Has anyone come across a method to do so?
Fix'd
I figured I'd get that for you before some of the other grammar nazi's come in here :D
I think OP means the "DROIIIIIDDDD" robot sound? If so, any ringtone app will have it. Try Zedge.
If this is about the bars, there isn't much of a difference between the notification bars, just the color. Which I think you can change if you have root.
Mabila ringtones has the "Droooiiid" notification sound. I too thought it was pretty cool and downloaded it for my SMS notificaiton sound...
