Help How to I activate 3g?
CooLoser
I know its a nexus s 4g but i have my ns4g flashed to boost mobile but cant get data to work. 4g wont work on boost obviously so how do i turn on just 3G?
As long as mobile data is enabled it should work. There is no toggle for 3G that I know of. You may also have to check the box for data roaming and make sure you have the right PRL. Not sure if boost is the same as like Verizon but dialing *228 for instance is how you update the PRL on their network.
you have to have boosts data settings on ur phone. i dont know those but there different than sprints. im sure google has them somewhere. then update ur prl. 3g will work then.
