Unlike a regular thermostat, the Nest Thermostat is smart in the sense that you get to control it remotely with your mobile device, create schedules and routines, and more. This means that instead of your home being heated or cooled at a fixed temperature, the Nest Thermostat will let you change it automatically.
You can set it so that when you’re not home, it doesn’t turn on. You can also set it so that when you’re home, it can turn on. These kinds of automation features can go towards helping
