sushigeneral
hmm... it doesnt seem to work
Welcome to the forums!!!!!!!ok so i want to root it. i forgot to backup my apps so i did. and i started over again. the problem is, is that when i pressed the power+volume down button, it doesnt do anything!! what the heck?!?
I'm not a pro at this so here are my questions.
1. What is the recovery slot?!
2. I ran the Android Flasher but it said "Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue."
Hey guys. I'm a noob at this so could you help me at these problems?!? Plleeassee!?!??
1. I tried using the ADB method and once I got to the command window and typed the following, they said they couldn't find it. What should I do/what's wrong?
2. Once I'm done with that, what do they mean by putting it on my "card"? Do they mean my SD card? If they do mean that, how?
3. Can you give me easier steps? I don't understand the rest of the steps. I did step 1 and I unlocked my bootloader. So now what?
What if I used unrEVOked?
Hi guys. I totally appreciate this forum, especially the instructions when rooting but I think it's a little overwhelming with the abundant replies and such so can you go to my thread and reply some of my questions? It's called: HTC Evo Rooting Help with Gingerbread 2.3.5. I made this because I need help! I havent got to recovery and I'm at a deadline. I want to make sure I root my phone soon so I won't procrastinate about it later. Thanks!
ocnbrze said:1.ok did you enter the command from the android folder? do you have the
correct files which is listed in the guide?
2.yes the card is the sd card. i will edit it so it will not confuse others.
3.well that will be up to you. with the HTCdev method you can flash roms and kernels like any other rooted phone. only difference is that you can't update your radios and your bootloader will be watermarked.
using unrevoked will require that you follow captain throwback's method to downgrade your bootloader so that you can use either unrevoked or revolutionary to get you fully rooted.
If you are talking about the recovery slot mentioned in the step for Android Flasher, (step 6) it is one of the options on the Android flasher screen where you would click browse to find the amon ra img fileHey guys. If you read my message from "[Revised] Rooting Gingerbread 2.3.5 Dummies Guide" you know I want you to come here to answer some noobish questions.
First, I can't seem to understand recovery slots. What are they and how do I get there?
How do I get to recovery?
Does unrevoked work? What are the cons? I've heard it's not as good as you think.
More questions but that's all I could think of since I haven't got that far.
