Help Huawei Accent G510 mic issues
henryc
Hi guys. I have a problem with mic on my Huawei G510... after certain amount of time (30sec to 1min) mic switches off on regular calls (incoming and outgoing). The issue solves after uninstalling VIBER. Any ideas how to solve this problem - in order to use VIBER on my handset? Thanks a lot
That's interesting. I suggest a factory reset. Rooted? If so, wipe the dalvik + cache. I've ditched the G510 for a Jiayu G2F wcdma, it's performance is outstanding, unlocked and runs on the 900/2100 Mhz wcdma networks. It actually cost less than the G510, but I've had to root it and remove chinese crapware. If only the chinese would give up the crap and sell their devices with bare minimum, unobtrusive apps, and include high capacity quality batteries, they'd be set to wipe out the big names. That's my only complaint with the Jiayu G2FW, the Android System is consuming a large quantity of battery and it drains quick when in use.
Sorry to somewhat hijack your thread, but I just had to say it :)
