I7500 runing 2.2 dead
shiroko
Hi all, im a new member on this forum and first of all id like to say hi to every1..
I have i7500 witch was running on 2.2, i got it like that from a friend, but now when i want to turn it on it just stops on start up at GALAXY AOSP logo.
Can i flash it back with the original firmware ( I7500IJ1XX ) with it's downloader, i think it's 1.5, or 1.6 or do i have to put the 2.2 again. If so can any1 post a link on how to do that? Or is there anything else i can do. Any help would be greatly appriciated..
Hi all again i managed to revive my phone and it's working good now, i just have 1 problem left i cant connect it to my pc in normal pc suite mode it just connects in mass storage mode is there anyway to change that?? Please help
Hi and welcome to the forums, sorry for the delay.
In your phone's settings, under Application, you will find USB debugging. Try enabling it or disabling it, depending on its current state. There should also be an option like "mass-storage only", which you should deactivate.
Why do you want to use the PC suite? It's not exactly a good software. ;)
Thanks for your reply,
i dont really need the Pc suite, but i need the phone to be in pc suite mode not in mass storage in order to unlock it. I was searching for that option "mass storage only" but cant seem to find it anywhere in the phone, do you know aproximatly where it's located, you would help me a lot with this...
Thx again
To unlock the phone, you probably should use Odin to install a Samsung firmware on the phone. I don't think it can be done with a custom ROM.
Try checking in Settings -> About -> Additional settings. ;)
