ICS on huawei m860 using cm7 port
amalloggi
DISCLAIMER:I am not responsible for any damage caused to your device
download the file attached
use root explorer to paste it in system/app
BEFORE YOU EXIT CHANG THE PERMISSION TO RW-R-R
press home check the box and select ics launcher NOT 64.OPIN
customize the launcher to your liking
REBOOT.
for those easy modders i will post a link for a modded cm7 ics version soon the gapps and roaming off are below
HERE IS THE ICS ROM (I TAKE NO CREDIT FOR THE ROM JUST FIGURING OUT HOW TO MAKE IT LOOK LIKE ICS): http://www.4shared.com/zip/k3Zwc6ZK/CM7_ICS_PORT_HUAWEI_ASCEND_M86.html
TO SEE HOW THIS LOOKS GO HERE: http://www.youtube.com/watch?v=DLdIe4Uig-U
HAPPY MODDING!!!
:):D:D:D
:D:D:D:)
