There is a neat hidden menu on your new Android Marshmallow phone or tablet that gives you a bit of control over your status bar and it's pull-down menus — the System UI Tuner.
Once enabled, you can change the way your status bar and pull-down settings look and feel, giving your Android a more custom feel that would have previously required some rooting and flashing.
