Root Installing V6 Supercharger on a rooted (with Basix, and Electric Sheep) phone?
mariano81
Hello my fellow android forum members, I am looking to making my galaxy indulge even better!
I am currently running my samsung galaxy indulge with the following:
  • Rooted with the iao in this website (took 5 minutes!)
  • Basix 1.0 (took less 5 minutes!)
  • Electric Sheep (took less 3 minutes!)
  • Overclocked with the SetCPU app. (with the "max" set at 1300 MHz, the "min" at 200 MHz, and with "Scaling" set "ondemand").
Now, in order to make this phone even better, I am looking into V6 Supercharger. According to this thread, it says:
"It makes your phone FAST... super snappy with better multitasking!
It rearranges and fixes the OOM Groupings and Priorites and lowmemorykiller values.
So basically, it's a COMPLETE MEMORY MANAGEMENT FIX!
So I want that! So here are my questions:
  1. Have any of you installed V6 Supercharger with a setup similar to mine and many of us? If so, what is your experience with V6 Supercharger?
  2. If i install it given the instructions on the link above, will it break my current setup?
  3. Care to share with this forum how you did it?
Thanks in advance!
The script is pretty self much self explainatory, every option works except the option to interigate with system. Select NO on that option it will lose root and you can't get it back without reflashing the rom. Before you can run the script you have to download busybox installer from the play store, I recommend the one from jrummy, open app and install busybox version 1.16.2. Then use script manager to run it. You can also run the KAK script on it too, just do NOT select the option for I/O Schedule, use will have to reflash the rom cuz it will boot loop. In both scripts it will warn you of those options and effects so it won't be hard to miss or over look. The scripts are awesome!!
In the options use local.prop, its safer and it works.
I recommend creating widgets for superclean, run once a week or so, and one for engine flush, run that one anytime is starts to lag or every few hours.
no v6 supercharger wont work once you reboot your phone it will lose root then you have to reflash basix to get it back i dont know how he ^ got it to work but in my experience basix and v6 dont go along it lags everything gets screwed and you lose root after boot
You will lose root it you choose "yes" to integrate. It even tells you that you could lose root.
