PlayfulGod
Extreme Android User
DISCLAIMER: This is a CUSTOM' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, CyanogenMod 11 for the Galaxy Nexus (maguro)!!! Well, let's be honest, unless you're living under a rock, you probably know what Android 4.4 (kitkat) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod | Android Community Rom based on KitKat.
Version: 20131117
Developer: PlayfulGod
Description: CyanogenMod 11 for Samsung Galaxy Nexus
Source: All sources used from CM Repos now.
Status: Alpha - due to missing CM Features still.
CyanogenMod 11
What is this?
This is a build of the popular CyanogenMod 11 for the Samsung Galaxy Nexus (maguro). This is built from source.
People to Thank
Whats Working??
Whats Not Working??
Changelog
Screenshots
How do I install this?
If using sideload:
Downloads
Version: 20131117
CyanogenMod 11
What is this?
People to Thank
- CyanogenMod - Do I need to state why we owe thanks to these guys?
- koush - for his wonderful recovery.
- SlimRom - for their tuna device and vendor repos.
- Guys on freenode #cyanogenmod-dev, #koush, & #oudhitsquad for their assistance and advice.
Whats Working??
- Everything it seems
Whats Not Working??
- graphic glitches (about like any Kitikat 4.4 ROM out for the Galaxy Nexus)
Changelog
- 11.13.2013
- Initial Build
- 11.17.2013
- Using all CM Repos
- sync'd with CM Repos
- Gmail/G Search FC's fixed
Screenshots
- Download the .zip & copy to phone (make sure wifi is enabled if dl'd from phone).
- Zip can be installed from either sdcard or with sideload (No need to copy zip to phone if using sideload).
- MAKE A BACKUP!!!
- DO A FACTORY RESET!!! - this will wipe data & cache!
- Go to install zip from sdcard
- Choose zip from sdcard
- Select cm-11-xxxxxxxxxx-UNOFFICIAL-maguro.zip
- Confirm
- Repeat Steps 5 -8 for gapps
- Reboot
If using sideload:
- Download zip on PC
- Connect to PC via USB (make sure to have USB drivers if using Windows)
- Open a terminal or cmd window and type:
Code:adb sideload cm-11-xxxxxxxx-UNOFFICIAL-maguro.zip
- Repeat for Gapps.
- Reboot
Downloads
- 11.17.2013
- cm-11-20131117-UNOFFICIAL-maguro.zip
[HIGH]sha256: d2bf7bc1a9dc6da1a89d72ec8fa0a53418496c540ce9b8d30e7fcc6223cfb8ae[/HIGH]
Mirrors - Goo
Gapps - Gapps for use with Art by dhacker29
- PA Full Gapps for use with dalvik
