Is A Temp Root Possible?
chugger93
16
0
Is any sort of temp root possible? Sprint Hero? I just wanted to root, uninstall sprint garbage and unroot.
Most would say, well why don't you leave it rooted? Well I don't have a good answer for that. I guess I dont wanna jack anything up. I'd want to phone to function like it is now. Plus I'm not sure if rooting gives you that main menu (dos type window) when u boot up. Didnt really want that.
Any comments are welcome! Thank you!
Not to my knowledge there isn't, using the RUU will unroot it and return it to stock but you would get the bloatware back.
The phone would continue to function the way it is...no menu on boot up. I think people make rooting out to be a far greater deal than what it is. If you don't tinker with things after you do it chances are it's not gonna "jack anything up" ;)
Upvote 0
What about when 2.0 comes out tho...will my phone update without error. I guess thats my biggest concern as well.
you MIGHT have to flash the recovery before trying to update to 2.x. But within a day or so of 2.x coming out, it'll be rooted again. So basically it'd take an extra 15 minutes or so to update, due to doing the recovery and re-rooting/deleting apps.
I could be wrong on this one though, and it'd be great if someone could clarify it.
Upvote 0
Basically if you want to keep root, you will likely have to wait for the devs to alter the install file so it will work on the rooted device. The reason being that 2.1 could very well fix the exploit that was used to gain root.
Upvote 0
BEST TECH IN 2023
Smartphones
