Hi,
I have purchased Micromax A78 mobile last month. With this mobile I am facing the following three problems;
1) The Battery backup is coming only one hour while I am using Internet on mobile and the backup is coming only half day while normal use.
2) The Photos & MP3 songs are automatically erased from the SD memory card and the same was storing into the folder called LOST.DIR with unknown file format further same was not opening.Frequently it's happening.
3) Automatically the mobile showing the status of my SD memory card as "Damaged SD Card" then the phone was disconnecting from SD Card. If Iam restarting the mobile then the SD Memory Card is OK for working. Frequently it's happening
Anybody pls suggest me to resolve the above.
Is the battery backup increase If I update the Mobile Software by going to Service Centre..?
Other than the above issues the mobile is Superb within it's price.
-B.Srinivas
-B.Srinivas
