It takes forever for my phone to ring!!??
tap58892
Ok, so I am having MAJOR problems with my (now 5th) replacement HTC Eris. I just can't seem to part with it though because I do like it. Anyway...
I remember when I first got the phone, it would ring about 5 times on the callers end before it rang on mine. I found some number that I called to fix that... now I can't find it anywhere!! HELP!!!
Some devices don't do well on the default slot cycle setting.
That is the setting that determines how often the phone contacts the nearest tower, in seconds, to query for incoming calls; the stock setting is "2," which translates to three times as long as a setting of "0" and twice as long as "1." Those are not seconds, just settings. The actual seconds are longer than "0" for a setting of "0," obviously.
The factory setting of "2" is designed to sacrifice quick caller to receiver functionality a bit in order to save battery life. The lower settings keep the device busier than the higher settings, so prudent battery saving measures taken in other areas of the system should be taken, such as lowering the screen brightness, leaving GPS off until actually needed, etc (see http://androidforums.com/htc-droid-eris/19176-optimize-your-droid-eris-battery-life-read.html).
To adjust the slot cycle, you must access the slot cycle index, which is accomplished by doing the following (be patient between steps, a bit of a delay occurs sometimes):
- press the "phone" button
- dial ##778
- press the green "call" button
- choose "edit mode"
- enter six zeroes as the password (000000)
- press modem settings
- press slot cycle index
- make your selection
- press "menu"
- confirm your setting
The device will reboot.
- dial ##778
- press "menu"
Thanks Frisco!
Q: Does this ever get reset .. say, after a reboot or battery pull? I set this to zero a while back, but it somehow reverted back to "2". (Although, it may also be that I simply neglected to confirm.)
Thanks Frisco!
Neglecting to confirm is the most likely reason, DEinMA, although a factory data reset will restore the device to all default settings.
A live battery pull would not cause the slot cycle index to change.
Ok, I have not factory reset so it must be the former.
I will also say that I have had a dramatic decrease in missed calls since I received a replacement phone. And now that this setting is in place, it should be even better moving forward. :cool:
Thanks again
The only time I noticed that the slot cycle changed on my phone is when I got a replacement. It seems that setting is for the specific device, not the phone number.
i dial ##778 and nothing happens! tried it 4 times now
it worked. call confirm must have been stopping it. mine didnt reboot though. but its still at 1.
Try removing the HTC weather/clock widget from your desktop and rebooting the phone. Also try the slot cycle tip and report back to us.
