Ok so to start off I'm new to most of this. I got everything rooted and all set up with ICS, but I didn't really find anything different with any of the other versions that I couldn't get with the stock version. I have tried the JB ROMs but have had problems with all three of the ones I have tried. I know that none of these are perfect I just want one that sorta works.
CM10 seems like the best choice but when it starts up I can't get the touch screen to work properly. I have a small circle that moves around the screen and in order to do anything I need to double tap then hold for it to work. This is also the case with MIUI version as well.
Evervolv I can live without Bluetooth, MMS and even a buggy cam. But I need WIFI and I don't need it overheating and bursting into flames. Also and maybe I didn't work with it enough but I would like Google Now if possible.
I realize that all of this stuff is a work in progress but my hope is that someone else out there has run into the same issues and might have a solution for one or all of these. Thanks in advance.
