BH_MAN
Android Expert
Download > http://eb-productions.proboards.com/index.cgi?board=b2d&action=display&thread=213
Install Via ODIN
EXT 2 OC kernel @796MHz
~ msm: Support for configurable ondemand frequency range (cyanogen)
~ Drakaz &bukington Change cpu voltage via sysfs
~ Remove debug in acpuclock.c.
~ Added IPV6 support
~ Updates to Def_config
~ msm7k: Update defconfig with stable clock settings (cyanogen)
Needs Tested: Wifi Tethering
More changes underway...
Things to do.
~ Add swap
~ Memory Hack
~ 3dhw Fixes Patch
~ Few misc Patches as well.
~ Make RFS Version Friday at some point
Ext2 Speed Results.
Install Via ODIN
Things to do.
~ Add swap
~ Memory Hack
~ 3dhw Fixes Patch
Ext2 Speed Results.
