Root [KitKat GApps][11/02/13][JB 4.1.2 ROMS]
starkraving
Android Expert
Over View:
Hey guys and gals I've been playing with the recent N5 system dump and scouring various sites/sources for KitKat (Android 4.4) apps that are backward compatible to 4.1.2 to give Elite users a taste of KitKat.
I'm putting together a thread to centralize all the compatible things and will update it as I make more progress. Most things work with the exception of GoogleHome, DeskClock, Calculator and maps.
These all install like normal APKs so here we go...
Must install new Google Play Services (Now and Hangouts are dependent on it.)
Download Google Play Services:
https://db.tt/MDPA0be2
Google Now
Download:
https://db.tt/tBIvORMv
Required Lib for Google Now
Download:
https://db.tt/tzVUFJj4
Use a file explorer to copy to system/lib and set permissions to rw--r--r--.
Hangouts
Hangouts now integrates SMS/Hangout conversations.
Video chat fixed, add this lib to system/lib, set permission to rw--r--r
Download:
https://db.tt/iwsh5bMf
Download:
https://db.tt/2r6O92fp
GMail 4.6.1
Download:
https://db.tt/IJRvtNQ4
Email
https://db.tt/wcHE5WDW
Calendar:
Download:
https://db.tt/qqvAbdHj
Camera:
Download:
https://db.tt/qrt3yyxa
Flashable libs for camera:
Download:
https://db.tt/BpGCLGyU
Gallery:
Edit function force closes app.
Download:
https://db.tt/S0Ij5K0N
Google 4.4 Keyboard:
Download:
https://db.tt/7kxI0uUg
Google PlayStore:
Download:
https://db.tt/ePjtTHFf
I'll continue to update this as things are ported/back ported. Thanks to Android Police, stackforum, techfox, XDA and all the other sources I've pulled from. Enjoy and remember I'm not responsible for what you break. If you like my work hit the thanks button. :)
Screen shots
I wonder if I can grab the packages from 4.4 and build them with 4.1
Well they're all signed...the only issue I've found is Google Home...it force closes and its got something to do with not having offline voice recognition/ search. If we could get offline voice built in we could use the new launcher. But sure I'd imagine you could.
@phenomx4 there's also a issue with the dimensions for the launcher. Anything hdpi and smaller have the keyboard randomly popping on the home screen. It seems to be working best with xhdpi/xxhdpi ... Id love to reverse engineer it to work with this device but that's above my paygrade. Any thoughts?
Question: which file manager is the best/easiest to use for installing the lib files for hangouts and googlenow?
I tried placing the lib files in the directories as instructed but cant even do that without receiving some weird error that the file cant be opened in order to be copied/moved... I'm using ES Explorer at the moment.
I've personally always used root explorer a paid app by speedsoft. A good free alternative is jrummys root explorer.
@freedomwarrior, pm sent. :thumbup:
