Help Knox Contacts help
androidexpat
Anyone know how to get some contacts from a phone backup into Knox Contacts? I do not want to put them in to my regular contacts and it seems like in Knox one can not access the SD card. What I had wanted to do is be able to pick the contacts from a previous back to be put into my Knox contacts instead of the regular contacts.
As of now it seems like the only way to do this is manually one by one. There has to be another way. Anyone know how?
Never heard of Knox Contacts. I just tried to add a new contact and Knox is not one of the options. Where did you find this?
Once you log in you should see contacts in Knox. Third one to the right on bottom. Great feature to keep applications like Facebook and others from reading your contacts info.
Very cool idea but either I'm in the wrong spot or just blind. Log into what? And what app/setting are you in?
This is very interesting and want to know more
Here
Here you can see options in setting for contacts under Knox with no import options. Do they really want you import/add each contact manually from your previous contacts list from a previous smartphone if you are upgrading to a new smartphone?
Well that explains it. I don't have the KNOX app on my AT&T Note 3. Well I do have the app if I look in all apps, but it is nowhere to be found in the app drawer. Time to see what I can find
Let me know if you figure this one out, Thanks.. I like the Knox contacts,gallery and email option as it is supposed to keep your private info private and away from other eyes along with being away from permissions that many applications require when you download their applications.
The odd and puzzling part though is though phone shows Knox and it being locked all the incoming and outgoing calls can still be seen in the Personal part of the smartphone as well as the Knox part. Maybe a bug or so,ething
