Help legend wont play music. SO ANNOYING!!!!@
I have a bit same kind of a problem. I copied music from the bundled memorycard to one I already owned.
So far so good, the music that came with the bundled card is found by my Legend and played back quite nicely. But when I try to add more song to the same folder with same kind of folder structure... Nothing. Those songs are not displayed in the player at all.
I have tried copying the files to the sdcard in the following folders:
.\MP3
.\media\audio (and various sub folders)
The difference between the files that came with the original card and that I have copied seems to be the size: The bundled songs are about 10 megs a piece where as the songs I have copied are just a meg or two.
I am able to play those sings just fine on my PC from the mounted phone though.
So,
my question would be, how am I to get my own MP3s to the phone and be able to listen to them and set them as custom ringtones?
Thank you for your kind assistance.
Upvote 0
.\MP3
So,
put ur mp3 to ./music folder. then remove ur card and insert it again. this should solve ur problem.this worked for me.
Upvote 0
Thanks for the tip, but did not work.
I've now checked the firmware to be of the lastest version and formatted the memory card with the phone. I am now in the process of copying the stuff back to the card (I could've actually tested if the format did any good with a single song) hoping that the songs would be available this time around.
Upvote 0
BEST TECH IN 2023
Smartphones
