Help LG G2 (D802) Fastboot Mode!!! Phone is Bricked..Need Help!!
I have LG G2 D802..
I installed LG Mobile Support Tool on my Windows 8.1 pro, attached my phone with USB Cable. Update was available. I updated my cell. Everythng went good. But when I restarted my phone. It was stuck on LG Logo. Please help. Fastboot mode :(
url]
i tried everything...but when i give command in fastboot...it shows like this...nothing happens
Try instead of erasing just immediately
fastboot flash boot boot.img
what you can do is to have the recovery perhaps erased so you can still always enter fastboot mode or just immediately flash with fastboot the TWRP recovery too.
try fastboot devices to see or the device is also good connected, else try to reconnect the phone.
i have all the image files...but when i do this...as u told..this happens
  • 2015-05-19 23_13_57-C__Windows_system32_cmd.exe - fastboot  flash boot boot.img.jpg
i get question mark...when i try fastboot devices command...although i have installed all the drivers necesary...
I have LG G2 D802..
its not only im facing the same issue in my lg g2 d802 im also worried, in device manager there are no qhsusb_bulk instead of android.
Im also stuck here dont know what to do...
