Root lg g2 stuck at security error with no recovery and lg flash tool not working
hey guys,i had cloudyg2 v3.1 and TWRP on my g2 d802, than i wanted to install CWM so i flashed a cwm img with flashify, i rebooted to recovery it gave me a security error, but i could restart the phone normally, than i tried restoring stock recovery with autorec app, when i rebooted the phone gave me security error, now i can't start the phone cause it always give me security error and shuts down, i have no recovery, and lg flash tool which always worked is now stopping at 2%, please help me guys, i tried everything i found googling about this but nothing worked, thanx in advance.
If I was you,Iwould start over by returning to stock and start over.
First see if you can get into Download Mode,If so start here:
http://forum.xda-developers.com/showthread.php?t=2432476
And before flashing back to stock,Remove the sim card as it will wipe it clean and then put it back in after flashing.
the phone goes to download mode normally, but as i said in the question, lg flash tool isn't working anymore, it always stops at 2% and gives me error, it used to work fine but after this probleme it doesn't work, i have proper drivers installed and everything
What got jacked is you tried to install a ClockWorkMod Recovery while you had TWRP Recovery installed.What I see is a conflict between the two.
This is what's wrong as far as I can tell.
man i'm not a noob per say, i used that method a lot of times and it always worked fine, but it won't work i don't know why
Just take your time and follow the instructions word for word,And be sure you use the proper variant for your device.
EDIT:The TOT method is the easier one.
Usually Cloudy roms change the model number so they error when flashing in Flash Tools. It may help if you hexedit the tot/kdz to whatever model number Flash Tools "thinks" your model is. It should show up in the error report when the flash fails so you'll know what to use.
