Hi to all of you with speed lag issues. This worked for me.
1.swipe all apps off the desktop.
2.drag back installed apps to desktop.
You should notice a marked speed difference. Good luck. Try with one app first and see if its faster.
Regards Mark NZ
No worries, like I say I had all my apps organised and tidy with kitkat and then had a system update to lollipop 5.0, I opened an app in the organised desktop location (so slow) I then dragged the same app from the main app storage and was way way quicker. Good luck
