So when it comes time to update my LG G3 phone (which is my pride and joy lol) and my Asus Memo Tab ME102A do I do a factory restore with them also?
I was wondering if it recovered everything so easily because I had already installed Lollipop anyway?
It's recommended (but not essential) to do a Factory Reset after any major system upgrade.
I've installed every upgrade from 4.1 to 5.0 and NEVER had any problems, I've never had to blank my nexus once, so that's strange that you had to.Didnt know that before. But thanks to you all it now has made my nexus 7 faster again.
I also meant to say they gave me a free movie Frozen when I upgraded !
All i need now is to find out how to stop my nexus 7 taking a day to charge!!!!
You might want to check that the power output is the same from both the nexus 7 struggles if it doesn't get exactly the right amount of power.The default wire stopped working within 6 months. Using my lg phone one now
Really don't know how to do this.You might want to check that the power output is the same from both the nexus 7 struggles if it doesn't get exactly the right amount of power.
You'd need equipment, unless it's written on the packaging or the adapter.Really don't know how to do this.
No, I some cheap Amazon branded wires which charge phones and low power tablets but just fail altogether fail at charging Nexus 7s.Had thought they were all the same
I've noticed that many applications are slow/lagged and I often get kicked out of them. Yahoo email and Facebook are horrendous! If I cared more, I'd be pissed, but as it is it runs a bit better with the update.
This is after a Wug's install and FDR.
