You need to format your SD card as internal storage before moving apps to it.Marshmallow 6.0.1 SD fix? anyone get this figured out yet? I can't chose the external SD as a save place for apps.
only a couple that say root only, if I had root access I wouldn't need their app.
Virgin LG Power X
Hey thereMarshmallow 6.0.1 SD fix? anyone get this figured out yet? I can't chose the external SD as a save place for apps.
Virgin LG Power X
You can use an app called Link2Sd to move apps to sd card specifically and it wont cause any portability problems toook I just wanted to be able to set a program to save files to the external SD card. And yes I want to to be usable readable on other devices. I was able to do this on my other two phones but this new android runs well but is sure strick.
