mysticrayne0
Unable to save to sd, I end up running out of memory, is there anyway possible for me to get the Samsung Galaxy Victory to save to sd?
What would you suggest for best results in rooting?
I am trying to save apps
Trying to move apps to the sdcard? That feature is not in android 4.1 to 4.3. The victory is 4.1.2. Dont know why google removed it from jellybean. But with root it can be done. You need to root, then add a 2nd ext4 partition to your sdcard. I can walk you through it if you think you're ready for it.
OK, This app will root you. Its called towelroot. Just install it and click "make it rain". Then go to the play store and get SuperSU and install it. Open it and let it install binaries, choose "normal", not twrp/recovery. You will then be rooted. I will get you a file to install TWRP recovery. In the meantime, also get the app " flashify" from the play store.
Install on computer? went to link and it doesnt have a download or install link
Sorry. Try this one https://www.dropbox.com/s/22dvyjju3zcid7f/tr.apk?dl=0
Just download on phone and install app.
No working, it says restricted access and says file no longer there or available
says it worked but when I went to download link2sd it rebooted lol
After you open towelroot and click " make it rain" you're rooted. Follow my other step and get and run SuperSU. Also get flashify but don't run it yet.
What do you have so far?
