AlabamaHit
Ok..I'm sure this was asked before, I appoligize for that. I did search but found nothing.
I am trying to get my phone "Stock Rom" + "Root" + "SD Internal Memory"
I can't link because I am new, but I can stock my phone because I have a spare to get a recovery from.
I will be using "stayboogy" Root update.zip. (HUGH THANKS!!!!!!!!)
What I would like is after the root...I would like to use the SD Memeroy as Internal.. Like send 2gig to it.
I have tried stock, root, and cwm. But memery don't show. I'm sure it is something to do with the kernal from what I have read. I have also tried to run a "ext3" and "ext4" kernel. After reboots...Nothing...still the same.
I know I might get suggested to use a custom rom. But I would really like to keep it stock, because I get many crashes and error with every rom I have tried. (I'm sure it is something stupid I'm doing. That is why I would like to do it stock because I'm stupid, and it seems it would be more simple)
Phone: ZTE Merit (NET10)
Thank you very much for anyhelp guys.
