stayboogy
Android Expert
METRO v2.0.777
with
777Mhz Overclocked Kernel
and
TouchNav System Recovery Utility
FEATURES
TouchNav System Recovery Utility (both ext and vfat versions)
777Mhz Overclocked Kernel with ext4 and swap support
rooted
Blue Steel Themed
init.d scripting
custom cpu management--never go below 777mhz--user customizeable
dalvik-cache relocated to /dev
optimized for space
minimal ram usage
best, custom, system apps
Install one and done!!!
And all of this in only one update package file!!!
And it installs on any setup--any model, any version, any recovery!!!
Disclaimer: I am not responsible for any damage that may or may not result from the use of this rom or kernel. You are responsible for what happens to your device. USE AT YOUR OWN RISK.
NOTE: MAKE A BACKUP BEFORE YOU INSTALL THE ROM
NOTE: YOU CANNOT INSTALL THE ROM AND THEN JUST INSTALL ANOTHER BOOT.IMG. IF YOU DO SO, YOUR WIFI WILL NOT WORK BECAUSE ITS DRIVER HAS TO BE BUILT WITH THE KERNEL. IF YOU WANT A VERSION WITHOUT THE KERNEL, USE v2.0
DOWNLOADS
(remember to rename to update.zip if installing on stock recovery)
*wipe your data before you install. you can try to just delete your dalvik-cache, but if rom fails to boot then wipe all userdata and install again*
**first boot will hang at ZTE logo for nearly a minute sometimes. this is normal**
***all boots will be long because of the dalvik relocation and rebuild and because it is deodexed***
METRO v2.0.777 with TouchNav System Recovery Utility (ext)
METRO v2.0.777 with TouchNav System Recovery Utility (vfat)
THEME ONLY HERE
with
and
FEATURES
rooted
Blue Steel Themed
init.d scripting
optimized for space
minimal ram usage
DOWNLOADS
THEME ONLY HERE
