MetroPCS and Huawei help!!
Carmenin805
Ok so I thought i was so cool when i bought my Huawei, but it has been more of an embarassment. The first one i got kept disconnecting me from the network. After many reinstalls and updating roaming lists and don't forget the lovely calls to tech support they finally ask for $10 and 3 days later i get another phone. Well this one seems to be fine, it's 1 week later and my calls are dropping,i notice i have no bars sometimes i have the x with my bars. I look and network status is once again disconnected. I am at my wits end and i so don't want to deal with them. Can anyone offer some help here? PLEASE!
Have you been having this issue everywhere you go? Btw you may have better luck posting in the section dedicated to your specific phone model.
Go to the settings and tap the wireless & networks. Scroll down to mobile networks. Tap system select and whatever it is set on, try the other setting. Also, make sure all of your gps stuff is off, you can find it under location & security. Ther may be a couple other settings that need tweaked. Depends on your phone make and model. :-)
