Just wanted to know if i transfer systemui framework from any TW rom to any other TW rom.
For example if I wanted to GalazyRom UI on metropolis could I easily tranfer that without any repercussions
Thanks in advance.
I don't know anything about these ROMs but if the ROMs are similar and they are of the same Android version, they could possibly work.
This is something I would use Android Commander for. That's what I use whenever I push any type of file or apk to the phone via PC.
What do you want that is in one framework/systemUI that's not in the other? Might can just pull what you need out.
Thanks, I really just one the example i mentioned lol. The whole overall theme of GalaxyRom onto metropolis.
I took a quick look at galaxy rom. The dev thanks the wassabi theme installer in his post. Chances are he used that to theme galaxy rom...which means you can theme metropolis the same way using wassabi theme installer. Morphology comes with all of the wassabi themes. That would be where I'd start. Safer than swapping in stuff from other roms.
[Wipe][Auto Theme For Our S3] - Android Forums
Go to the link I gave and follow the directions...there's a process that must be followed and a patch that must be installed in order for morphology to work.
in my opinion i have crossed swap such system files and it will only work under 2 conditions! if they from same build of android 4.1.2/4.2.2/4.1.1 etc and same rom type like for example touch wiz to touchwiz. and i highly agree android commander makes pushing/pulling files from android super easy and effortlessly. doing it the manual way creates lots of fc.
not if you do it correctly
be gone demon!!! go work on cm10 for the esteemers they still have faith on you lol jk i still prefer android commander its hassle free and hassle free is the only way to be. you shizzle?
I dont doubt it is, but knowledge is power, thus knowing how to use adb properly is a plus.
