MetroPCS Connection Problem Cube T8
Hey guys, I have a rather vexing problem. I just recieved my Cube T8 phone call tablet (phablet) and went through the process of calling Metro PCS to have them assign my SIM card to the IMEI of my new phone. After doing that started my phone up and noticed there was no signal, so I check my settings and the phone could read my sim and showed my phone number, but also said under carrier "Emergency Calls", So then I checked my APN and saw one from t-mobile already there, so I added the one for metroPCS (at least I hope its the correct one). Finally I checked under Network Operators and saw it found several signals including one from MetroPCS, but when I try to select it to connect, after a minute or two of trying it simply say "Unable to connect to network at this time, please try again later". It seems that no matter what I try, the phone gets no phone or internet signal. I am at my wits end. I have run out of things to try, so I come here. I am reasonably sure that the phone can read the SIM, and can also detect the network and is just not accessing it. I am also fairly sure that they changed the IMEI properly considering I have gone back and forth a few times, one of them at least should have gotten it right. So I am here looking for any sort of insight or advice I can get. I will appreciate any help I can get at this point. Thanks in advance!
