Root [MetroPCS] help please i need to get to 12b to flash
Also, if you do unroot and for whatever reason the update notification won't come up (it didn't for me once in my many complete resets because I messed something up :P) go to Settings>About Phone>Check For Updates, it should be the option at the top.
it's about the same if i'm correct but if you have any problems tethering make a thread on the forums and we will help you as much as we can
I'd recommend posting it in the rom thread other than making a new thread ;)
But i can answer that question, tethering is the same as stock, you have to use the tethering guide we have here
I tried all that but in android tuner i cant find hostpd to kill and when i tried to change set stick guid it wouldnt make the changes. What am i missing?
Oh nice it worked! But i can only tether my tablet, my ps3 connects but metro blocks it, i read to kill dhcpcd but it didnt work. Do you have any suggestions?
