INTRO
This is a modified stock ROM for Metro PCS LG Optimus F6. Since this is a stock based rom, it's stable and you can use it as daily driver.
Apps are Zipaligned and Debloated. You can immediately feel the phone is snappy and fast. Most of LG and Metro apps are removed, that will give you close to 1GB of internal space. It's still not enough but hope this will give little more room to users without using Apps to External SD method.
ROM install is done through Aroma Installer so you can choose preferred apps and tweaks during install.
ROM FEATURES
Made from toilet drowned F6... (
http://androidforums.com/lg-optimus-f6/871368-dropped-f6-in-toilet-_.html)
Version 12b recommended
Zipaligned, Deodexed, Debloated
Loki-patched Insecure Kernel
Updated LG Home Launcher with 7 additional themes
LG G2 Keyboard with 3 additional themes
Aroma installer - customize Apps during install
- 3 Launcher selection
- 5 Keyboard selection
- 2 Email app selection
- 2 Browser app selection
- 2 Theme selection
- Extra tweaks & apps selection
MANY THANKS TO
hroark13 - updater script
Towel Root - root
pressy4pie - CWM apps
GameTheory - various help and inspiration
![Smile :) :)](/styles/smilies/google/smilie.png)
Trevor Philips - Useful guides and help
Ama Rullz - Aroma Installer
Madaditya - Lazy Aroma Installer
DOWNLOAD
Version 2 (current)
https://drive.google.com/uc?id=0B69dMfqyU4n9RmZuck5mcjlKd28&export=download
Live Version 1
https://docs.google.com/uc?id=0B69dMfqyU4n9N1ZXYzBsWDltajQ&export=download
Beta
https://docs.google.com/uc?id=0B69dMfqyU4n9ZWRWbmFCMHpFUlE&export=download
* Older versions don't mean they are bad or unstable. They still work and can be used on daily driver.
INSTALL
** In order to install this ROM, your phone must be rooted and have access to recovery mode.
1. Download the ZIP file then copy it to the external-SD card.
2. Go to CWM
3. Make backup of your current working ROM, if you haven't done so.
4. Wipe Data / Factory Reset
5. Wipe Cache Partition
6. Advanced -> Wipe Dalvik Cache
7. Mount and Storage -> format /System
8. Mount and Storage -> format /Cache
9. Mount and Storage -> format /Data
10. Mount and Storage -> format /data and /data/media
11. Install Zip -> Choose Zip from /external_sd
12. Find out F6_Dana_.zip file -> Yes. Install
13. Aroma installer will start. Follow the step by step guide.
14. If you see any error during installation DO NOT RESTART the phone (uncheck the checkbox at the end). Just exit to recovery mode then use Restore using pre-made Nandroid backup from step #3.
15. If install success, restart the phone.
16. First reboot will take longer than usual. If you see MetroPCS logo, give it couple of minutes. If you see LG logo, it's boot stuck. Do the download mode and restore it using KDZ flashing method.
16. Once it boots, set up your account & test all functions.
17. Thank you for using my humble ROM. Your donation, fee back, comments will be all appreciated.
~ Updated Log and Screenshots below ~
