Help Mic works when I call but not when I answer....
I flashed my warp n860 with CM and love the mod but hate the bugs. One in particular is bugging me. If I call someone I have mic but if I answer a call the mic is muted. So the only way I can talk to people calling me is on speaker. I know it's not a hardware issue because everything worked perfectly before I flashed it. Anybody have a solution for me?
Thanks in advance,
Patrick
Thanks in advance,
Patrick
It's a bug with the rom, that was directly mentioned in the original rom thread. The bugs are being smashed out quick though, and progress is being made. Keep in mind that this is over a year's worth of work for a phone which never had the source code released for it. You're right about it not being a hardware issue, but there is no solution at this point. Also, this type of question belongs in the Boost Mobile All Things Root section, more specifically, it would've been better if you had posted in the rom thread so other users with the same question could see it. The rom can be used as a daily driver as a phablet-ish rom for deactivated Warps, as its already gotten to the point where the only bugs are really a few of the sensors, audio routing, wifi indication, and the camera, but for now we just gotta hang tight with the gingerbread based roms we have now. Most of the gingerbread roms are fully working, however :)
