chin checka
MMS Fix For Boost Android CM7.1 HROARK
Pretty Easy To Do..
Remove MMS.apk & MMS Odex.apk if u have the odex version
Go To Android Market
Install GoSMSPro
in go sms pro app
hit menu>settings>>MMS settings>Fill APN config Manually
Enter:
MMSC: Http://mm.myboostmobile.sprintpcs.com
MMS proxy: blank
MMS Port: 80
THATS IT. PICTURES SHOULD NOW BE ABLE TO BE SENT & RECEIVED USING WiFi Or 3G Using Any Default Regular Messaging App..
HOPE THIS HELPS OUT.
Pretty Easy To Do..
Install GoSMSPro
in go sms pro app
Enter:
MMS proxy: blank
MMS Port: 80
