Motorola Universal Portable Charger P793
Reverence
I purchased the Motorola Portable Charger Model P793. The little black box with the blue mini usb connector. It was definitely used when I got it from the store, and I was wondering if I might be missing a piece of it because it didn't come with a wall adapter to charge the portable charger.
It came with the actual portable charger (the black rectangular box) and a USB cable, but no wall adapter to plug it into to charge the portable charger. Is this how all the portable chargers come and I am expected to use the AC wall adapter that came with my phone to charger it....or am I missing something here?
Set Your Location
Not 100% sure, because I bought mine a few months ago. But I'm pretty sure I was amazed that mine didn't come with the AC adapter either.
edit: I just read on a review that once it's drained you'll have to plug it into a usb outlet. So I'm guessing that means it doesn't come with the AC adapter. I myself have plenty of microUSB AC adapters that I can use.
Do you think it would be okay to use it with an HTC wall adapter?
I just got off the phone with Motorola and they said there should be one in there....so they are sending me one via UPS. Should be here in 4 days. The woman on the phone wasn't very knowing, so hopefully I get the right part.
There shouldn't be a problem using the htc charger. As long as it's not putting out over 950mA. It says on the back of mine Input 4.75-5.25V == 0-950mA. So as long as the charger output is between those specs for Voltage and mA.
