MTP mode for Kies? (Note 3, SM-N900)
Christon
Hi !
Connecting my Samsung Galaxy Note 3 (SM-N900) to my Windows 7 PC via USB. Kies says: Please, connect your device! I connect, but it never finds it. I cannot find the way how to enter MTP mode (KIES3) as it suggests. Any hints?
Thanks
First off welcome to the forums :)
If you pull down the status bar at the top of your phone to view your notifications there should be one for how your device is connected to your PC.
If you click on it you can switch it to MTP Device.
I think this device has some serious problems.
-Does not connect to Kies3
-I cannot install a Google Play Services
-I cannot delete some applications
-GPS does not work at all. Tested with GPS Status and GPS test applications
-I'm waiting for the firmware upgrade to 4.4
If there are that many issues, and a factory reset has been performed, just as a test to see if these problems persist, I would definitely suggest to return to your carrier store and get a new device.
I've tried this and there is not indication of how device is connected. Is there a way to turn that feature on so it can be used?
