Help My Phone reboots when connecting to Openvpn / Droidvpn
rudrateja
I have installed tun.ko successfully. I felt happy :)
But every time When I try to connect Openvpn/Droidvpn My phone is rebooting. I tried it on both Ninad's UB-75 Rom and Root5 Orginal rooted rom. I tried to use it with different VPN config.
Busybox v1.19.4 - Installed
Openvpn Installer 2.1.1 - Installed (Binary Installed in /system/xbin/openvpn)
Openvpn Settings 0.4.10 - Installed
Tun.ko - Installed (Installed using tun.ko Installer)
Same thing is happening with Droidvpn.
In XDA forum I have read that this happens in Android 2.3.4 & 2.3.5.
[Q] When browsing with enabled VPN, phone reboots itself. - xda-developers
Anyone having this problem?
Here is the Openvpn log..
Tue Mar 13 22:55:00 2012 OpenVPN 2.1.1 i686-pc-linux-gnu [SSL] [LZO2] [EPOLL] built on Jan 7 2012
Tue Mar 13 22:55:00 2012 MANAGEMENT: TCP Socket listening on 127.0.0.1:24269
Tue Mar 13 22:55:00 2012 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Tue Mar 13 22:55:00 2012 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Tue Mar 13 22:55:00 2012 WARNING: file 'client.key' is group or others accessible
Tue Mar 13 22:55:00 2012 LZO compression initialized
Tue Mar 13 22:55:00 2012 Control Channel MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Tue Mar 13 22:55:00 2012 Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:135 ET:0 EL:0 AF:3/1 ]
Tue Mar 13 22:55:00 2012 Local Options hash (VER=V4): '69109d17'
Tue Mar 13 22:55:00 2012 Expected Remote Options hash (VER=V4): 'c0103fa8'
Tue Mar 13 22:55:00 2012 Attempting to establish TCP connection with *.*.*.*:* [nonblock]
Tue Mar 13 22:55:00 2012 MANAGEMENT: Client connected from 127.0.0.1:24269
Tue Mar 13 22:55:00 2012 MANAGEMENT: CMD 'state'
Tue Mar 13 22:55:00 2012 MANAGEMENT: CMD 'state on'
Tue Mar 13 22:55:00 2012 MANAGEMENT: CMD 'bytecount 0'
Tue Mar 13 22:55:01 2012 TCP connection established with *.*.*.*:*
Tue Mar 13 22:55:01 2012 Socket Buffers: R=[87380->131072] S=[16384->131072]
Tue Mar 13 22:55:01 2012 TCPv4_CLIENT link local: [undef]
Tue Mar 13 22:55:01 2012 TCPv4_CLIENT link remote: *.*.*.*:*
Tue Mar 13 22:55:01 2012 MANAGEMENT: >STATE:1331659501,WAIT,,,
Tue Mar 13 22:55:01 2012 MANAGEMENT: CMD 'bytecount 0'
Tue Mar 13 22:55:02 2012 MANAGEMENT: >STATE:1331659502,AUTH,,,
Tue Mar 13 22:55:02 2012 TLS: Initial packet from *.*.*.*:*, sid=3e7e7d04 b4a6d763
Tue Mar 13 22:55:02 2012 MANAGEMENT: CMD 'bytecount 0'
Tue Mar 13 22:55:17 2012 VERIFY OK: depth=1, /C=IE/ST=IE/L=Dublin/O=GL/CN=GL_CA
Tue Mar 13 22:55:17 2012 VERIFY OK: nsCertType=SERVER
Tue Mar 13 22:55:17 2012 VERIFY OK: depth=0, /C=IE/ST=IE/L=Dublin/O=GL/CN=server
Tue Mar 13 22:55:42 2012 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Tue Mar 13 22:55:42 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Mar 13 22:55:42 2012 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Tue Mar 13 22:55:42 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Mar 13 22:55:42 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Tue Mar 13 22:55:42 2012 [server] Peer Connection Initiated with *.*.*.*:*
Tue Mar 13 22:55:44 2012 MANAGEMENT: >STATE:1331659544,GET_CONFIG,,,
Tue Mar 13 22:55:44 2012 MANAGEMENT: CMD 'bytecount 0'
Tue Mar 13 22:55:45 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
<<<<<Here My phone is rebooting>>>>>
Have you tried installing a different busybox version?
You also need to set the busybox path on DroidVPN if you want it to use your busybox installation.
Sometimes this can also be caused by a faulty ROM. So installing a new rom could possibly fix this.
Yes I have tried it with different busybox versions.
I installed Busybox in /system/xbin path and selected Busybox path option in Droidvpn to the same.
As our handset don't have kernel source. We have only couple of modified Rooted ROM's which are made by Ninad. I tried it with Both ROM's
When connecting via Openvpn, I observed that my phone is rebooting after this line >> "SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)"
As you know I am not Working on this topic ...
but just to inform,
The thing is,
Any ROM you use b4 getting source code, will be same in the Extreme basic core ... :)
Hence ROMS will not be a problem ! (still )
