UPDATE: did some PATH hackery ... this is not a fix tho ....
rmccurdy.com/nmap.sh (tested on CM6 / mytouch slide )
in normal mode ..
in "Android system recovery (2e)" :
( note: /system is also a vfs I think .. I adb push to it and reboot and the file is gone ... )
Code:
mount -o rw,remount -t yaffs2 /
rm -Rf /nmap
mkdir /nmap
echo 'export PATH=$PATH:/nmap' > path
cd /nmap
wget http://rmccurdy.com/stuff/G1/BINS/NMAP/NMAP.zip
unzip NMAP.zip
chmod 777 /nmap/*
echo run /nmap/path before you start nmap
nmap -vvv 127.0.0.1
in normal mode ..
Code:
bash
localhost / # mount -o rw,remount -t yaffs2 /system
localhost / # cd /system
cd /system
localhost system # for i in `ls` ;do mkdir $i\\nmap ;done
mkdir: can't create directory 'app\nmap': Out of memory
mkdir: can't create directory 'bin\nmap': Out of memory
mkdir: can't create directory 'build.prop\nmap': Out of memory
mkdir: can't create directory 'etc\nmap': Out of memory
mkdir: can't create directory 'fonts\nmap': Out of memory
mkdir: can't create directory 'framework\nmap': Out of memory
mkdir: can't create directory 'lib\nmap': Out of memory
mkdir: can't create directory 'lost+found\nmap': Out of memory
mkdir: can't create directory 'media\nmap': Out of memory
mkdir: can't create directory 'usr\nmap': Out of memory
mkdir: can't create directory 'xbin\nmap': Out of memory
Code:
C:\Documents and Settings\Administrator\nmap>adb shell
- exec '/system/bin/sh' failed: No such file or directory (2) -
