Nightspear
After spending a few hours searching the forum, I have found a few similar instance. However, none of the solutions worked.
I have 16GB Nexus 7 2012 model Wifi only. I am stuck at the Google load screen.
I used the Nexus Root Toolkit (NRT) to load the Google driver and unlock the bootloader without a problem. I clicked the root button and I am guessing the root failed, because it just sat at the Google screen for over an two hrs. I can load the bootloader and scroll through all four options. When I select run or recovery, I get sent back to the Google load screen. I left it plugged in to my Windows 7 pc over night to verify it was finished loading. Nothing had changed in the morning.
I have Googled many methods before searching this forum. My problem with the manual method is I can not access the tablet to enable the USB debugging. The tablet is no longer recognized in Windows, and NRT doesn't list the tablet in fastboot mode and ADB mode just gives a blank list.
If you need anything else let me know and any guidance is much appreciated.
Thanks,
Nightspear
Thanks,
Nightspear
