Help Need help in using USB OTG
TF85
Hello,
I am using the SVHD 1.7.5 rom witch has an usb OTG support.
I hope use the an external usb (stick for example).
An USB OTG standard cable doesn't work, why ?
Need help.
thankx
Do you connect the cable with the stick?
There might just not be a notification about the mount. Have you looked for something like "USB Storage" with a file manager?
Harry
