Root Need Help with 4.1.2 Update
J4son3
Hello all.
First of all. I'm an Android newb. I did get my N7 unlocked and rooted a while back. I could connect to WPA Enterprise netwook at my workplace so I gave up on my N7. I hear with the latest update WPA Ent is working. Here is my dilemma.. I don't know how to update. I tried under"about tablet"-system update and it says I'm up to date. I downloaded the update zip file, but don't know what to do with it. I even tried to Flash Stock and Unroot with the toolkit. Nothing is working. Can someone give me a hand? Thanks in advance.
Patience. Since you're stock and unrooted now, the easiest method for you would d be to wait a while and watch the update roll in OTA (from google's servers).
Very few people actually have had the update OTA yet, most of what you read comes from enthusiasts who flash new builds the second they are sniffed out.
Google rolls out these updates gradually over the course of a few days.
Alternatively, you could flash manually as well. I'm pretty sure you can use the toolkit, but I'm not at a pc right now so I can't check. Make sure you're on version JRO03D of jellybean tho, the zip you have will be for that version, no other updates are known atm.
